well they do in appendix D of part pbuilding regs don't stipulate cable colour do they?
the area that this regulation is intended for is electrical installations that are in, fed from or attatched to dwellings, and in the gardens or lands of a dwelling where the suppliy is from inside teh dwelling..P1 Reasonable provision shall be made in the design and installation of electrical installations in order to protect persons operating, maintaining or altering the installations from fire or injury.
If it's thinner it won't work as well, which probably means it won't work well enough.
Also - what about vapour control?
When you cut holes in the Celotex you'll also be perforating the membrane which stops moist air from getting into the unconditioned space above, condensing, and rotting the roof timbers.
the "approved documents" are not law.. they are guidance to the law and often branch into areas of non statutory regulations..
Part P of the building regs in it's simplest form says
Schedule 2 then lists the kind of work that is notifiable, but ALL work is covered by part P1 above..
but on searching the S.I's I have to admit I cant find anything to the effect that the above quote is statutory so therefore I am going to change my view and now agree with you coljack (and Bas)Q2: What are the requirements of Part P?
From 1 January 2005 it is a legal requirement for all work on fixed electrical installations in dwellings and associated buildings to comply with relevant standards. The relevant UK standard is BS 7671: 2001, 'Requirements for electrical installations' (The IEE Wiring Regulations 16th Edition). BS 7671 covers requirements for design, installation, inspection, testing, verification and certification.
And there is a good case to say that the law requires you to use old colours to extend/modify old installations if you can....
well with that I can't argueAnd there is a good case to say that the law requires you to use old colours to extend/modify old installations if you can....
You are - just note it as a departure on the EIC...to use old with old, common sense if you ask me(if only we were allowed to use it these days)
I meant "common sense" on the whole but duly notedYou are - just note it as a departure on the EIC...to use old with old, common sense if you ask me(if only we were allowed to use it these days)
MMm - stick end of wrong, I got - mmm.I meant "common sense" on the whole but duly noted
No no no. BAS really means if you use common sense, it must be listed as a departure from conventional practice on the EIC
