I have had a ceiling re boarded and skimmed in the spare bedroom. It had 5 R39 spotlights that I am replacing with new fire rated gu10 downlights, fitted with LEDs.
The old lights were double insulated no earth and the new ones will be the same. The old ones were daisy chain wired so each light fitting had one in and one out to the next, except for the last one.
The new lights dont have enough room for wiring this way. From reading here I see the correct way is a junction box at each in and out and a flex from that to each light, and best practice is to use heat resistant flex. But I can only find heat resistant in 0.75 in a two core.
So do I use 0.75 heat resist or 1.00mm non resist because on reading here 1.00mm should be used but canot find it in heat resist
