Agreed, but if it were old 'flat twin without earth', then the conductors would be the same size as T&E. Anyway, as you will have seen, the OP is going to re-check the nature of the cable, so maybe it is T+E.It is the OP stating that the terminals will not take two conductors which make me think it is T&E - it is difficult to imagine that the terminal will not take two 0.75mm² flex conductors.
Yes thank you, I like the look and design of them - perfectI don't think there is aproblem.
If the OP is now having to use junction boxes -
These are good and specially for the purpose.
- twin and earth can/will be used from box to box and the small flex to each light, so the regulation is met.
That's all very well, but, strictly speaking, the regs require a CPC to be run to the fitting, even if it is DI ... and since the OP has now found the earth, that should not be a problem (with 3-core flex).if its only a short bit from J/b to a double insulated fitting its sometimes easier to get 3 core and pull the earth out hence making it 2 core
Thanks - that what we were rather expecting. That means that you should be able to run an earth connection from the JBs to each light (even though they don't need earths!) if you want to be fully compliant with the regs.OH MY OH MY ... SORRY EVERYONE ... I have just been up and there is an earth.
JohnW2";p="3383557 said:Theoretically, you should make sure that these earth wires you've found really are connected to earth, but that is probably less of a priority since you are not going to be 'using' them.
Kind Regards, John
Unlessssss -----------
To be honest one of the reasons for going for those fittings was because they did not need an earth (not got them yet ) because I thought that I did not have an earth ( above that ceiling anyway).
So now I know I have an earth I am not restricted to fittings that dont need one.
I had an electrician fit a light pullcord in another bedroom and I think he tested the upstairs lighting then but how do i test for sure
And if the fittings that I get have enough room for a loop in and loop out can I do it this way with the existing flat twin and earth or do I still have to use a junction box and flex for each one, I am now looking at the ansel icage which states it has a generous connection box for loop in and out
And also as no one has jumped on it - I am assuming that the method that was used 17 years ago to connect the earths twisted together outside and under the junction box is ok then, (not ideal but ok)
Fair enough, but if there's a chance that you will need an earth, then you really should test (or get an electrician to test) to confirm that earth wires you've found really are connected to earth. Do you have a multimeter?Unlessssss ----------- To be honest one of the reasons for going for those fittings was because they did not need an earth (not got them yet ) because I thought that I did not have an earth ( above that ceiling anyway). ... So now I know I have an earth I am not restricted to fittings that dont need one.Theoretically, you should make sure that these earth wires you've found really are connected to earth, but that is probably less of a priority since you are not going to be 'using' them.
Yes, if the cables will reach and if there is enough space in the fitting (and terminsals will take to conductors).And if the fittings that I get have enough room for a loop in and loop out can I do it this way with the existing flat twin and earth ...
Not really. I would have thought that that (once common) practice would have more-or-less died out by 17 years ago, and it's certainly not really acceptable today.And also as no one has jumped on it - I am assuming that the method that was used 17 years ago to connect the earths twisted together outside and under the junction box is ok then, (not ideal but ok)
Probably not - it looks like there is a terminal block that's slightly remote from the lamp housing. but you must follow whatever the MI (Manufacturer's Instructions) say.Do I have to use heat resistant flex (will be led lamps)
