You really, really, really have to find out whyThe lighting circuit is still drawing a large amount of current at random intervals even though everything apparently attached to it is switched off..
Pir activated patio heater?Or what about an outside PIR activated light?
Indeed so - and, as I said before, that's the sort of amount of current that would be needed to trip a B6 in around 5 minutes. If it's some genuine load which has somehow been wired into the lighting circuit then fair enough (although it needs to be found and sorted out) but, as I also said before, if that amount of power is being dissipated in some 'fault', then there would be a very real fire risk.If your meter LED is the usual 1000 imp/kwh then that's about 2KW being drawn. That's a fair amount of heat.
Honestly you need to keep it off, especially when you're out or in bed! Especially away.In the meantime the MCB is staying switched off.
It's been suggested you call a different electrician.I'm going to call back the electrician
