Hi all,
First time poster, but have done a fair bit of reading in search of information previously.
My problem in a nutshell (albeit a large one) -
Oil fired central heating
External boiler
Pumped System
I've a 3 zone/channel system in placed controlled by a Horstmann H37 XLPlus controller panel, heating downstairs rads, upstairs rads and water seperately.
Currently, when mains power is on to the H37 controller despite all zones showing as off, the outside boiler is firing and heating the downstairs rads.
Upstairs and the water remain off but do function as expected when using the controller.
2 Myson Power Extra motorised valves control the flow for downstairs & upstairs zones. When the boiler is firing despite the controller showing all OFF, no operating lights are shown on the downstairs Myson valve despite water continuing to circulate through the downstairs system.
Turning the controller on (and with the room thermostat turned adequately down) the operating light on the Myson will show on as expected. Turning off the downstairs system via the controller, switches the operating light to off on the Myson valve and you can hear the mechanism within make its typical whirring noise as it stops. The water in the downstairs system continues to be heated however.
The outside boiler is not constantly on but does still regulate its temperature itself, so it does continue to cut in and cut out as it feels necessary for the duration that the mains power is on.
So my question is whether I have a faulty controller, faulty downstairs Myson valve or is it a combination of both?
Or is the fault likely between the controller and boiler itself?
(apologies for the long post, but trying to provide as much information as possible)
Any information or ideas appreciated!
Thanks,
Ciaran
External boiler
Pumped System
Thanks,
Ciaran
