No Mick.
No combined feed and vent.
I just thought that maybe I should combine the old feed and vent into each other.
Maybe I am totally wrong here though.
The system goes as follows. Hopefully this makes sense. Thanks for the patience by the way
Old system (worked)
Out of boiler, into a radiator, into the next radiator, into the next radiator, into the next radiator, then up to the cylinder. Out of cylinder, round the upstairs rads and back down again.
Basically there was no DIRECT flow and return to cylinder only.
Plumber cut and tee'd the original flow and added in a direct one to the cylinder. Removed old flow from cylinder and capped it off.
Took new return into cylinder, ran back to boiler house and tee'd that in there. removed pipe that used to go from cylinder to the vent pipe. Capped it off.
Valve put on down at boiler to control flow into old rad flow pipes
Fitted valve at cylinder flow pipes.
Fitted stats, electrics etc to control it all.
Fitted auto air vent up at cylinder valve.
I think thats basically it.
What went wrong?
Old system (worked)
What went wrong?
