So as to give air flow to the void under the joistswhere would my ventilation go?
what if i didn’t. as outside is being rendered.So as to give air flow to the void under the joists
Doesn’t matter if you’re getting banksy to paint it, no vents no building regs approval.what if i didn’t. as outside is being rendered.
Also you say here that the dpm and dpc are not linked for a suspended timber floor??“ stud the floor “, “ lower than the dpc” if you mean you are constructing a suspended timber floor, the dpm and dpc are not linked. There are a multitude of illustrations of the detail to be found online and ,bless them, the NHBC 5.2.10 covers damp and ventilation for this
You’re planning on fixing joist hangers with 2 screws good luck with your project and even better luck with Build Control ( perhaps use private rather than local authority).ok i understand this. but as i said earlier when the dpm goes up the wall can i penetrate this now and again with 2 screws for joist hangers? if not how else am i going to keep the joists in place?
four screws then, either way i’m asking about penetration of the dpm.You’re planning on fixing joist hangers with 2 screws good luck with your project and even better luck with Build Control ( perhaps use private rather than local authority).
so just 50mm blinding sand and then concrete underneath?You don't have a DPM with a timber suspended floor
timber ground floors. so a floor with timber, raised or non raisedWhat does the first line say ?
Timber ground floors:
- 50mm concrete or fine aggregate on a polyethylene membrane laid on 50mm sand blinding, or
- 100mm concrete.
