Hello All
I have a DPS thermal store (300l) connected to a condensing gas boiler (Worcester 42CDi). The store currently supplies an Invisible heating UFH system (4 circuit) and the DHW.
I have a radiator circuit that comes directly from the boiler which is controlled by a single room stat and timeclock with a zone valve for supplying it when heat is called for.
The DHW heated by the thermal store is continuously on (not a timeclock).
This worked very well when I first installed the sysytem. Recently I have noticed that the availability of DHW is less, even running a standard size bath drains the DHW. The thermal store has a 'quick recovery' system with large plate HX from the boiler. It appears to be cycling more than before, even after running a sink of hot water.
I recently replaced the main pump (it was noisey) from the boiler to thermal store but this has had no impact (good or bad) on the performance.
The UFH works as expected.
Is it possible that there is an airlock in the thermal store or pipework suppying it?
Could faulty thermal store stats be at fault?
Does anyone have any general advice or need further information to help with trouble shooting?
Cheers
Cheers
