drainage
18 Apr 2009
Manchester
does anyone know if there are any issues regarding burying 1.5" solvent weld waste pipe in concrete as long as i sleeve and observe fall.
i cant forsee any prblems with this as long as the joints are clean and glued properly try using a scotch pad to rough up the pipe before gluing this will ensure a good union at joints make sure the cuts on the piping are straight and no burrs are there you should make sure that it is sleeved as lime in the concrete can make problemstoo
