- Joined
- 8 May 2017
- Messages
- 10,125
- Reaction score
- 2,625
- Country
No. Once all pipework is done ,and local isolation valves fitted ( I.e one on each ,hot and cold to every tap etc) you then turn mains water on and fill everything up. You then have to run water through each isolator ,via a hose or any temporary connection ,to a drain ( or a large bucket if need be) to flush out the pipework of any sediment ,solder / flux or any other contaminents that may have got into the pipework as a consequence of you working on it.
Once flushed out ,you then can connect taps/ showers /toilets etc .
