I tried to drain my combi's primary circuit yesterday by isolating the feed and return, turning off main water supply and then opening drain tap. Once the drain stopped I tried to remove the CH pressure diff cover plate to replace the diaphram but was met with loads of water that would not stop. Am I missing something? - Is there an other way to get the water out of the system or do i have to just catch the water until it all runs out
