My problem was similar, no signal no matter which buttons I pressed. Changed batteries, 1 had leaked so cleaned the metal connector in the tray, still no signal received. I found the fault was the metal battery connector in the battery tray which wasn't touching both batteries. I got a screwdriver behind it and bent it out a bit. Did this with both trays and hey presto, signal received.
Just to add to the knowledge here, I just had the same problem.
In addition to the steps already outlined, I found I had to move the RF unit within 6 inches of the SCR unit, otherwise no communication occurred. Even 12 inches was too far away.
i.e. a weak radio signal for some reason (perhaps caused by interference with home wifi maybe??).
