Quick question for anyone out there - is there an alternative mid-position Actuator which will fit onto a Drayton MA1 3-port valve, and which I can just fit onto the valve after removing the possibly problematic actuator currently in place?
I then noted that the "kick-space " heater in the kitchen (which is part of the CH system) continued to keep going - and kept on going (this heater normally would switch off about 5 minutes after the CH had reached its "satisfied" temperature setting as per the room stat's setting.
This obviously signifies that the CH is still actively being heated by the boiler as well as the HW - even though both have been switched to the "off" position at the programmer!!
I have an experienced heating engineer coming out on Monday morning to deal with this issue. Hopefully he will be able to dignose what's wrong and fix it. Like you, I reckon it's a wiring fault rather than a 3-port fault. But I would appreciate your thoughts on what you reckon it most probably is before he gets here, so that I can maybe point him in the right direction.
Would I be right in saying that if he knows his stuff he should be able to figure out what the problem is without too much trouble?
And tell me why it has been happeniing only intermittently?
Best wishes.
John.
ok turn both stats up and turn both central heating and hot water on at the programmer
If it were a wiring fault, it would not be intermittent; it would work or not. Change the head and the fault will go away, until the next one fails. These are not the most reliable valves.
no its doubtful as the stats are in series with the programmerOne thought which is nagging at me - could the programmer be the rogue element here? I mean in the way in which it's wired up to the other components. It's just that I don't understand how the HW and CH can be switched to the "off" position on the programmer and yet both HW and CH will continue to be heated up by the boiler - with the 2 temperature-controlling stats being rendered completely impotent when this glitch occurs.
John.
I hadn't read that this is only 7 -8 weeks old. Two possibilities are rogue feed from the HW off on the programmer, or more likely, the cylinder thermostat giving a feed out on both demand and satisfied terminals. This can occur intermittently depending on the temperature of your cylinder.
