Drayton RF1 thermostat
6 Jun 2005
Glasgow
I have a DRAYTON RF1 wireless digital thermostat connected to my Vokera Combi boiler. This boiler was installed in the summer, so haven't been using the clock that is on the boiler itself.
Now winter is approaching I have been trying to set the clock so that it fires the boiler up in the morning. However, whenever the thermostat is set to call for heat it fires the boiler up even if the clock is in "Auto" and the time is set so that boiler is not meant to come on.
In other words, it's as if the clock is totally bypassed !!!! Has my thermostat been wired up wrong? or am I just thick!!!!
Regards
Brian
You could be right about your boiler timer being by-passed. If so, you could consider changing the digistat RF1 for an RF2 or 3 which include timing functions. See brochure.
But this is really something your installer should sort out. Call them back.
I did think about getting the Drayton RF2 or 3, but then saw that it was about £100.
Because I had the boiler installed in the summer, I think I'll just get them back round ...and kill them !!! They can sort it out.
If I had the wiring diagrams (I've lost the instructions), I could check that he hasn't put a link in the wrong place. I'm an electronics engineer, so won't be a problem.
I live in Glasgow, we are starting to need our heating on in the morning, up here !!!!!
Brian
10p says the receiver wires are connected to the same terminals as the clock because the plumber who put it in didn't have a spare bit of terminal block- ??
If that's right then clock-ON would override the thermostat of course.
Thanks for all your help.
He had indeed bypassed the clock, I have managed to rectify it, with a spare bit of terminal block.
Brian
