Drayton Tempus 7 not quite working right
okay, done that. Just DWH on but all rads have now come on with vengance ! Storage came on too.
Don't know whether you saw my edit to the last post above.
Is that result with a wire still connected to terminal 2 or with it moved across to terminal 1?
Still wired as per conversion instruction.
When I turned hot water on all the rads came on hotter than when I just had the heating on.
I'm hoping the swap of the wire in terminal 2 over into terminal 1 will help the situation.
Have just done that. Will let you know if rads cool. Once cool I will turn the heating back on and let you know the outcome.
Fingers crossed all seems to be working fine now.
I will leave it all for a 24 hr run and report back.
Only thing I havent checked is if the DHW heats the rads when CH off.
Cheers so far. Steve
