Hi all, a combination of my own incompetence and the original house wiring being installed at an angle a few inches outside of a safe zone has resulted in me catching a lighting wire with the drill. After drilling the wire , the fuse tripped, when we turned the fuse back on, the lights worked fine.
I’ve turned the fuse back off to check the damage. I’ve chiselled out the plaster, broken into the conduit, and slit the sleeving, to find that the drill went into the live and the earth. Neither wire is completely broken but the sleeving around the live is broken and both wires are a little mashed.
What would be the best way to rectify this. I could just cowboy it by wrapping a bit of electrical tape around the live wire, but obviously would rather do something a little safer.
Would cutting the wire, installing a new section of wire to the switch, joining with Wagos in a low profile inspection box with blanking cover be the best way, or would crimping, a new section of conduit and plastering over be acceptable?
All advice gratefully received.
https://ibb.co/0mShGvj
