Regarding detectors, I have a Bosch Truvo and when I was installing some shelving used it to check for cables/metal work. One wall seemed to be live cables going in various directions even though there is only one socket on it. After reading the instructions I discovered if this happens you should 'ground' the wall by placing your other hand on it. Did this and was able to trace the cable accurately.
On Friday my FIL moved back into his new build bungalow so I decided to test my meter out on his home. I drew a sketch of his lounge/diner and tested all over the walls marking on my sketch where the cables 'appeared' to run. The builder and the legal eagles, i.e. insurance/architect/project manager etc came to lunch and I had spoke to the builder before and asked if he could bring the drawings with all the service runs on them. He duly arrived with the drawings showing where all pipes/cables/drains etc where running. I checked my cable sketch against his plans and they were spot on.
So maybe those of you who have problems with detectors need to calibrate your units and maybe read the instructions thoroughly. I thought you just held it against the wall but you don't.
