- Joined
- 16 Oct 2017
- Messages
- 7
- Reaction score
- 0
- Country
Hi folks,
I've drilled through the cable to a light switch (I think - the voltage detector didn't detect the cable prior to drilling, and it's a fair bit away from the vertical channel above the switch) - the only symptom is that the switch is not working. Nothing tripped in the consumer unit.
The wall is plaster over (very old) brick - there is very little room to effect a repair. Chasing the cable out of the wall is also going to be very difficult indeed - there is a mezzanine platform in the way. The only way into the ceiling space will involve cutting through the lathe and plaster or removing the bathroom floor upstairs.
For this reason, I'd like to try a crimped repair covered with self-amalgamating tape and plastering the fix back into the wall (assuming I can find the break!). Viable?
Cheers - Adam...
Cheers - Adam...
