You need to call the network provider, hoping is not really an option.
Really ? the same thing ?
I've only known of two fires caused by this locally
I find it hard to believe the contractor "took the screw back out",
I called the DNO, they have said that you can't overclad power cables and if we had requested they would have removed foc until the cladding was done and returned to re fix afterwards ?
The DNO says they can't remove the cladding and we need to request the contractor to come back to remove so that they can inspect.
Could they not test the current
Why does that come as a surprise/shock to you?P.S they've said someone will have to pay for the repair if needed !!
The repair will be chargeable to whoever damaged it.
Take photos of it in place before he does that, in case he tries to wriggle out of accepting the blame.The contractor is coming back to remove.
