Hi, I want to drill a 12.7mm hole in 3/8" steel plate. I have drilled a pilot 3mm hole to begin with.
My question is #1 on the amateur scale of dumb questions ....
should I drill gradually going up in size, eg 4, 6, 8, 10mm finishing off with the 12.7mm or go straight onto the 12.7mm drill bit but take it very slowly and with cooling fluid ... oil ?
The reason I ask is if going up in drill sizes will the hole stay centred or could it jump / elongate the hole ?
thanks
PS I'm only using an ordinary drill in a DIY drill press attachment, not a bone fide drill / bench press
thanks
