Drilling a concrete fence post
14 May 2007
Kent
How easy is it to drill through a reinforced concrete fence post?
Malcolm
Through, or into? I've drilled into quite easily in order to put up hanging basket brackets etc. Just try to guess where the rebar is to avoid having to re-drill if you hit it. (I think there's normally 4 rebars running roughly down the corners, google will show you more). I guess different manufacturers will do it slightly differently.
[code:1]-------------
| o o |
| o o |
-------------[/code:1]
Its very easy but like rjm says drill in the middle as they use spacers to space the steel when making them.
