Drilling big holes in travertine
22 Dec 2005
UK
Any suggestions on how best to do it?
I've got to put holes circa 30mm in the tile to pass tap bodies through. Drill a series of holes and link with a tile saw?
If you have a drill press get a cheap diamond drill from B&Q for less than a tenner.
The hole ended up needing to be 38mm.
For what its worth, a normal high speed steel hole saw with plenty of water cuts travertine perfectly!
