Tanking or overboard plasterboard with something stronger wont be of any benefit unless you mechanically fix through into the wall/stud behind, just bonding backer boards or using a tanking membrane over it will not make the weakest substrate (plasterboard) any stronger.
I don’t understand your tiler’s logic of putting up new MR plasterboard & then covering it with a 6mm tile backer board. I can guarantee your travy tiles do not weigh in at 6 kg/sqm & you need a decent 12.5mm backer board (you should only even use 12.5mm on walls) for tiles that size/weight.
At least youve seen sense with the "no grout" idea.
