Drilling holes to mount shower unit
1 Feb 2005
Tyne and Wear
Hi all,
Just to ask if when I'm fitting a shower or anything else to a tiled wall and the new holes to be drilled are very close to the old ones, how should I fill in the old holes?
the new holes being so close that I'd be partially drilling into the old holes.
wont be easy, the drill is liable to slip into the old hole & also as side of the new hole will be against the old hole, it be a 'good fix', & is liable to fail.
You would be better off finding another position.
