I have an RSJ that needs to be drilled so that a pipe can pass through it, hole size 65mm.
RSJ is an 'I' shape 185mm height, 100mm width and the span is 4.7 metres.
The proposed drilling posiition is within 0.5 metres of the start of the span , against the wall where it rest on the stone.
Edit: Just to add, I need to drill it out close to the top of the beam, obviously into the vertical section of the beam still
