I want to drill through my wall to move my sky+. I got my sds and bits etc. but the last 2 times i drilled through my walls for different things a big piece of brick came off looks a mess. I drilled inside to out is it worth drilling inwards
A good tape measure should sort out the positioning using windows etc as reference points. It is far easier IMHO to repair a bit of plaster than try to stick a bit of brick back on Also when going in from outside you can select to start the hole in a muck joint to eliminate damage to brickwork altogether.
If I have to put a hole through a clients wall I always give them the choice and almost invariably they ask me to drill from the outside in.
