- Joined
- 25 Apr 2016
- Messages
- 2,599
- Reaction score
- 615
- Country
Age of house - Lime motar? that does crack easily. That black hand you have I think is an indicator of a leaky chimney.
I think I'd be looking at getting a 'Smoke bomb' in the chimney to see if it's leaking and where they are.
Smoke bombs (https://www.toolstation.com/shop/p3...O9VWEvAIPt2KaY5I-JUym1xpQ1OMJKFxoCCQIQAvD_BwE) are used by Gas people to test the chimney integrity. When you set it off you need to have someone in the loft as well.
Edit :- it is worthwhile 'warming' the chimney first to ensure a good draw; try using a gas torch in the hearth pointing up the chimney for a period could be upto half a hour on a cold day.
I had a similar problem some years ago when I found the leak was in the brickwork at flashing line.
