Drop light gone after lightning
1 Mar 2008
Norwich
Have a drop light controlled by a dimmer in my lounge. During the lightning it blew. The associated lighting off the same circuit is fine (ie I have spots in same room with live from 2 dimmers together) & I swapped the 2 dimmers over to see if the dimmer had gone and it hasn't, the spots continued to work.
Question is do these type drops lights have their own internal fuse in the housing body, could it have blown all the bulbs (there about 10!) or has it killed the light & I need to replace. Its similar to the on the link & actually looks a bargain if I do need to replace!
http://www.habitat.co.uk/fcp/product/browse/5-drop-pendant/994897
Thank you :lol:
what are the bulbs?
12V?
could be a transformer blew in the light base.. ( they're electronic and succeptible to spikes )
Yes they are - if its the transformer am I best not to pee about & replace given I can get a good one for £35?
Thanks for your help
The fitting may be powered by an electronic 'transformer' built into the 'base' (ceiling rose?) which could have popped. Some transformers last longer than others, and some definitely don't enjoy being connected to dimmers.
It may be possible to fit a new transformer, depending on the design of the unit.
the transformer would cost about the same, so yeah, get a new one..
but verify that there is power to the thing first.. multi meter or swap it for a cheap normal pendant and 60W bulb..
