Water only leaked out of the copper pipe in the boiler when the bung was on the outside pipe. The pressure was at 3 bar but the water ONLY started to leak once I have turned the heating off. since then, I put a clear plastic bag on outside pipe to see if water is constantly being blown off thru valve & it isn't. At most there is just a bit of steam.
Re: PRV.
I explained it wrong. I pumped in 1 bar air and then opened PRV & it let the air out. I didn't think it should have done this as I thought this was only to let water out. [/quote]
Re: PRV.
