Dryer Condensate pump run
13 Feb 2020
I wish to locate my condensing dryer just under 3 metres from the drain. This will entail a horizontal run at the same height as the pump of about 3metres, (need to go under electric oven) before lifting about 60cm into the kitchen sink above its trap.
Do you think the pump it up to job? I could also install one of those condensate pumps used for boilers, or is there a better way to this?
Possibly, just give it a try. Run the dryer and have the hose at the same height/length setup as you propose. Let the pump kick in and see if it will raise the water up and out of the drain pipe into a basin.
