@pcaouolte Oh... I think I'll do some research on that case
I was actually thinking of buying a JML type clothes dryer.
Desiccant dehumidifiers like the EcoAir DD1 work ok in cold rooms where a compressor dehumidifier can struggle to extract any moisture. They do use more electricity because they warm the air in the room. Different technologies (desiccant or compressor) are suited to different environments.
That's amazing Harry, may I ask what dehumidifier you are using ?I'm not that convinced the compressor versions are that much less effective in a colder space. I use a 'tell-tale', a hump in the clear plastic drain pipe of mine, as a check that it is working. The hump quite quickly fills after switch on, and the clothes I hung up at 1pm are now dry at 9pm. I do run a fan at the same time, to ensure there is a good air flow around the room, to promote drying, but the temperature in there is only 9C.
OMG Harry that was a lucky find, I had an Amcor big tall upright thing for many many years but unfortunately the refrigerant circuit became perforated (like an old cars aircon) and a recharge lasted no time at all so I had to get rid of it (was over 20yrs old at that time). I don't rate the new stuff especially the current crop of Propane jobs, I don't think it's the refrigerant that's the problem, just the quality of products & there suppliers in this day & age!It was a Freegle one, free for collection. The original owner could not get it to work, because they had bent the inhibitor switch arm - for the water collection container. It say 'Amcor' on the front, around 10+ years old.
Apparently a compressor dehumidifier can run in temperatures ranging from 5-30°C with optimum performance above 20°C. Desiccant units are said to extract the same amount of moisture in any temperature between 1-20°C.I'm not that convinced the compressor versions are that much less effective in a colder space. I use a 'tell-tale', a hump in the clear plastic drain pipe of mine, as a check that it is working. The hump quite quickly fills after switch on, and the clothes I hung up at 1pm are now dry at 9pm. I do run a fan at the same time, to ensure there is a good air flow around the room, to promote drying, but the temperature in there is only 9C.
Yeah my kitchen gets pretty cold at night this time of year but the dehumidifier still does the job. I'll admit the clothes aren't quite as dry next morning as they are during the warmer months, however they're still a good way there with a fair bit of water in the container.I'm not that convinced the compressor versions are that much less effective in a colder space. I use a 'tell-tale', a hump in the clear plastic drain pipe of mine, as a check that it is working. The hump quite quickly fills after switch on, and the clothes I hung up at 1pm are now dry at 9pm. I do run a fan at the same time, to ensure there is a good air flow around the room, to promote drying, but the temperature in there is only 9C.
