I need to run a duct from our garage, under the (gravel) drive to the house. Specifically this is for a monitoring sensor needed for our planned solar install, but while doing this I'll also run two or maybe three Ethernet Cat5e cables. So nothing above 48V.
Are there any regulatory requirements on type and colour of duct needed, mimimum burial depth etc? The supplier has all sorts comments about it being a legal requirement to use the correct rated and colour duct. But for example is it acceptable to use electrical duct, marked as such and if I do then would that oblige me to lay it at depth required for mains service?
This is the sort I was looking at ..
Any comments welcome, thanks.
32/40mm Class 3 Electric Cable Black Ducting Coil (50m)
50m 32/40mm black ducting coil for electricity cables in Class 3 applications. With coupler and draw cord.
store.jdpipes.co.uk
