I have a Makita DBO 180 what do I use to extract the dust from it? Do I use Henry and some decent dust filter or I see the Makita Makita Dvc750?what's the most effective setup? Tia
For anyone interested i went and bought a Nilfisk Multi II 22L T Wet and Dry Vacuum Cleaner. I also bought a few extras for it, including power tool adapter and few other bits. I did note the standard hose isn't quite long enough so will buy a longer for when i intend to sand the ceiling. Im so excited about it arriving tomorrow how sad am i.
I shall post some pics and reviews on its performance if it helps.
The hose will want to come off if you're sanding the ceiling, so make it as secure as you can including with tape. The supplied dust bag plus a good P3 face mask might be a good alternative if circumstances require.
as long as the bag or filter in the vaccumn is to HEPA standards, then the harmful stuff that goes in will stay in - but as said above, plenty of dust will come out of the side and never go into the cleaner, so if you are doing a lot of it still use a good (p3) face mask
You might find the 2.2m length of hose to be a tad annoying. From memory each of my Festool dust extractors are have 3.5m hoses. Another issue is that your hose has the rigid sweep at the end that will be difficult to interface with you sander. Nilfisk are a decent manufacturer. Perhaps ask them for advice with regards to a compatible 3.5m hose with a flexible end.
