The shaver socket in my bathroom is very warm to the touch, plus it's not charging the electric toothbrush properly (charging light is bright as normal when first plugged in, but then dims to almost nothing within 2 or 3 seconds ... this doesn't happen if it's plugged into a normal socket via a shaver adapter).
I'm assuming the socket is knackered, but two questions before I replace it:
* Could the hot weather affect it? Any chance it will cool down when the weather does?
* It's mounted flush to the wall, but there's very little space inside the plasterboard cavity for the transformer, which looks like it's touching the back of the plasterboard in the next room (the section of wall in that room is very slightly warm to the touch, but not that you'd notice unless you were looking for it). Is this a problem, and could it have caused the transformer to be knackered?
Socket looks reasonably new - probably been there since just before I bought the place (about 3 years). How long should these things normally last?
Cheers
Cheers
