Hi, I am installing a new bathroom, I am using copper pipe with plastic push fit connectors, can anyone help me with regard to earthing the pipes and fitting earthing clips ect ect. Many thanks
copper pipes with pushfit connectors is about the worst combination, you can't use the connectors as part of the bonding path but you can't trust them to isolate either. Therefore either the connectors will need to be bridged or every pipe leaving the bathroom will need to be bonded seperately.
As normal any circuits supplying equipment in the bathroom (lighting and shower generally but there may be others too) must also be included in the bathroom bonding.
Hi, Thanks for your reply Plugwash, If the copper pipes entering the bathroom are bonded , is it ok to use plastic connectors on anything that is connected to those copper pipes.. Regards.
Hi, As I read it ,If the metal pipes are bonded as they enter the bathroom then the plastic isolates the rest of the installation. What do you think about that, Regards
To provide isolation there must be enough plastic though, a short piece like a push on connector isn't going to provide isolation hence the supplementary bonding is still required. It depends on how the pipework is run as to where bonding is required, do any of the pipes pass through the bathroom? Can you not solder yorkshire joints, would make life easier
