Greeny said:its only a couple of hours drive from birmingham can't you come down and see if the bonding has been done outside of my flat?????
no problem, I am on the way
Greeny said:if it is a live to earth fault why isn't the breaker tripping? i'll have to check whether there is still voltage there when i turn the fuse board off, im sure i did check that when i turn't it off and there wasn't any voltage?
Greeny said:if the sockets are incorrectly wired i.e neutral in the live wouldn't this trip it?
It is possible, amongst an array of other things.Greeny said:the breaker? so is it probably down to my sockets not being connected properly???
Qedelec said:On Yer bike!!
You haven't said if this AC or DC. I know its obvious to you but all factors have a bearing.
Have you any ELV lighting?
Is it present when all but the Ring breakers are made?
The advice you receive will be in direct propotion to the info you give.
