nope it was a dry lining box with no earth terminal
I see it now. I've used them before and there's nowhere to connect an earth wire - and nowhere on a plastic switch either. You were right to put the earth in choc block for future use.
If you look carefully you'll see that it would be almost impossible for a loose wire to come into contact with either of the switch fixing screws but ---
If you want to be 100% safe you could use plastic screws, which brings me to this:
if it is old wiring though( obviously i could search forever for the earth in the cable and never find it - even ithough there wasn't enough slack to do so) the extension of the switch over the door frame would not benefit from an aearth as there is no earth in the existing wiring, no?
It's possible that your dad's lighting circuit has no earth wire. There was a time when all lights (and a lot of sockets) were wired this way. I have a vivid memory of my mother plugging her iron into an overhead light socket.
We even had an adapter so that you could use the light at the same time.
From what I've read on this forum, some lighting circuits were rewired with nice new PVC insulated flat twin cable - but with no earth! Penny pinching or what?
If this is what your dad's got, think about scheduling a rewire at some convenient point. Take a look in the CU at the cables for the lighting circuits. If there are no earths in there, you'd be wasting your time looking for one in that old switch box.
Meanwhile, have a look around the rest of his lights and switches. Somebody might have fitted an unearthed metal one somewhere - and don't forget those screws. A metal screw in a metal back box can easily become live!
