So the front room of my house had all the plaster ripped off a few months back due to damp problems and is due to be re-plastered next year.
Well today I went to remove the wire terminating at a junction box from the only socket in the room and discovered the CPC of the cable was not connected to the socket , and thus also not connected to the cable going to the junction box what used to feed the other sockets before the room was stripped!
So In the nearly 4 years I have been living at my house, I have had un-earthed sockets in the front room. And no, I have never checked the sockets in there as I have not touched the wiring of the sockets in that room before and thus assumed everything was ok!
Also as is typical with old wiring, the single gang metal back box was unearthed, there was no rubber grommet round the cable entry. Further more the aluminium Line & Neutral wires were twisted and shoved into the terminals of a double socket, what the pattres box for the double socket was scrwed into the single gang back box making the tension on the cables excessively tight!
On a side note, as the single gang box has 4 screw lugs and has no built in provision for a earth connection, is it acceptable to earth the back box by using a eye crimp screwed into one of the unused screw lugs or do I need to replace the back box?
In essence, never assume something is all good.
