I'd love an excuse to use a thermite welding kit.
Could you not go above the ceiling (below the floor above) to get to an outside wall.I cant easily get to an outside location as the CU etc is in the middle of the house, hence one of my first questions was could I have the rods inside. Under the living room floor is the most convenient location otherwise it is either break a concrete floor up or go through 2 rooms and an outside wall.
You might get away with it, but one problem is that, without repeated re-testing, you would not know whether the earth had become inadequate (hence potentially dangerous) due to drying out. I also have heavy clay soil with a high water table but, even with my outside rod, its resistance can double during long dry periods.I have 2 x 4 foot rods that I was planning to use to whack into the subsoil; we are on clay here with a high water table so hopefully this would be suitable. I suppose if it fails the sparks test I would have no choice but to think again.
By the sounds of it you have a suspended floor downstairs - is there no way to run an earth conductor under that to a rod outside?
As Bernard said, rod(s) outside, not within any bounds of a building.I can put the rods in there?
