Earth wire at ceiling rose - odd tester reaction
26 Feb 2005
Gwynedd
I was asked by a friend to swap a light fitting in her lounge. Using a tester that beeps when held near a live wire, I tested for live, switched off the lighting circuit and tested for dead, whereupon holding the tester next to the earth cable still caused it to beep.
As I am clearly not an electrician, this had already gone past my pay grade, as I didn't understand why the tester would "go off". The earth cable was being used in the old fitting but not in the new, but anyway I terminated all cables safely for now and came here.
Any ideas what may have been causing the behaviour?
The volt pens aren't great for testing for live.
Chances are its not live and its just picking up static/magnetic field.
To be sure you should invest in a multimeter or test lamps.
They have their uses, but testing for live/dead is not one of them.
I would not trust one with my live/life, they work on non-contact electro-magnetics.
Always go with the two probe approved indicators.
We have a problem with our supply cable at the moment.
It did make me laugh when the supply company waved a volt stick at the fuses.
They tested the supply cable with a DVM and for good measure touched with his finger. It wasn't as if he was going to be working on it. It could of become live very easily.
