Missed this thread, but earthing that table seems like the wrong thing to do to me
Yes, they aren't designed for that sort of use, they are designed for use with fixed wiring where the cables would be clipped along their length and short of something snagging the cable and pulling reasonably close to the JB (eg within a few clips) then it wouldn't strain the connections.When I installed the electrics a few years ago I was met with the problem that these JBs don't have a cable grip as a plug or appliance would have - (if you ask me, the layout of the terminals also leaves a lot to be desired).
If you're happy with the current aesthetics, as Simon has implied, all you need is to clip the cables to the joist and all would be well - glands are not necessary.I need a better JB then, something with glands and half decent terminals, this one is shat.Yes, they aren't designed for that sort of use, they are designed for use with fixed wiring where the cables would be clipped along their length and short of something snagging the cable and pulling reasonably close to the JB (eg within a few clips) then it wouldn't strain the connections.
Most likely?I think the most likely thing to happen is cables getting damaged while using power tools on the floor - then as soon as the tool (damaged cable) is placed on the bench, the whole table top will become live.
If we worked on the basis of not bothering to protect against events which were 'very unlikely', then it would be a very different world. For example, you presumably agree with the earthing of exposed-c-ps of Class I appliances/equipment, but when did you last, in your house, experience an event which would have been a hazard in the absence of such earthing? You may even agree with the installation of RCDs to reduce the risk of electrocution!Most likely? Even if that be so, how likely?I think the most likely thing to happen is cables getting damaged while using power tools on the floor - then as soon as the tool (damaged cable) is placed on the bench, the whole table top will become live.
I was questioning the likelihood of the power cord getting damaged enough to cause the bench to become live.If we worked on the basis of not bothering to protect against events which were 'very unlikely', then it would be a very different world. For example, you presumably agree with the earthing of exposed-c-ps of Class I appliances/equipment, but when did you last, in your house, experience an event which would have been a hazard in the absence of such earthing? You may even agree with the installation of RCDs to reduce the risk of electrocution!
Very low likelihood, yes (but see my previous comments about that), but almost any powered tool (grinder, saw, router, drill etc. etc.) will have no trouble seriously damaging the cable of a tool.I was questioning the likelihood of the power cord getting damaged enough to cause the bench to become live.
What were you thinking of? I would have thought that little short of SWA would afford much protection against power tools, and that's hardly practicable for portable power toolsIf that really is a risk which needs mitigating then surely using a more robust power cord would be better than earthing the bench?
I'd suggest a better strategy would be to take better care of ones toolsIf that really is a risk which needs mitigating then surely using a more robust power cord would be better than earthing the bench?
