Hi, for some inlnunk reason when I opened up a double socket I could see that it wasn't directly earthed to the metal back box.
I know that it is "effectively" earthed via the socket screws but thought it was best practice to directly earth the back box to the socket. Having checked the rest it seems several are missing this.
I would normally strip the earth wire out of a 2.5 mm cable, earth sleeve it and use that... but was just wondering if the similar thinner earth wire from a 1.5 mm lighting cable would be equally acceptable to use?
Many thanks
Many thanks
