Yesdo you also have to earth the metal back box
ml1936 said:When wiring up sockets, do you also have to earth the metal back box? Or is putting both earths into socket sufficient?
TeesdaleSpark said:It's not necessary for flush back boxes as long as the boxes have one fixed lug and the accessory has an earth connection between the two screw holes.
Spark123 said:Although not required, for what its worth I'd fit them regardless!!
I'll take 20! Nothing worse than running out!JohnD said:I sell suitable Earth Links for this purpose, with well-terminated ends and top-quality sheathing in duo-coloured Green and Yellow PVC, skillfully trimmed by hand in convenient 150mm lengths.
They are £5 each plus P&P
I'll second thatSpark123 said:Although not required, for what its worth I'd fit them regardless!!
Pensdown said:I'll second thatSpark123 said:Although not required, for what its worth I'd fit them regardless!!
What happens when someone decides not to use a grommet and the cable gets damaged where it enters the back box? Without the flying earth the fault wouldn't be present when you removed the face plate but the back box would remain live to touch.
As stated in another post, 7671 is a minimum standard and IMO quite often it pays to exceed it.
But don't buy your leads from JD, I sell them complete with a crimp connector one end @ £4.99 inc P&P
Invisible-Man said:Surely you would isolate circuit before removing face plate
Adam_151 said:Invisible-Man said:Surely you would isolate circuit before removing face plate
Sometimes its necessary for live testing, and other times when you want to see which directions cables run in etc, you probably should isolate in most cases unless you need the power on for tests, etc (as it would not be too unreasonable to do so) but in the real world... heck in the real world accesories get changed with the power on!
