and another question if anyone can help . .
I recently fitted a new steel bath to replace an ancient cast iron one. the old bath appeared earthed so I dutifully connected the cable to the new bath . . then over christmas I was replacing some floorboards and discovered a loose earth wire not connected to anything. further investigation revealed the other end of it was my bath earth - so the old bath was in fact not earthed at all.
the flat is in a block with shared cast iron wastes going to the ground -
will connecting the earth wire to the caste iron wate provide a suitable earth?
thanks!
thanks!
