B
Big_Spark
Goofyish said:Surely the steel bath would be insulated from the earthed pipes by the plastic/rubber sealing washers and enamel between the bath and the taps taps.
This is what Goof actually said. It appears to be a question rather than a statement, and he has not qualified it by adding "this being the case means you need to earth it", or words to that effect.
Had he ended it like that then my reply would have been different or not appeared at all.
AdamW, bathwater may have a resistance of 100kOhmns, but the humans bodies is considerably lower, and if you provided the earth path for a fault current by earthing the bath, the current would be significantly higher than 2mA.
Wht do you think people die in Europe, the US and the Third world from electrical appliances falling into baths. A bad installation is all it takes for the item to remain live, and then when you step out of the bath..WAMMO..your worm fodder!
