Hi All,
I had an electrician around last week to do a few jobs, including extending an existing ring into a conservatory. Customer service was pretty low and although had all the badges, there were a few statements which made me a little concerned (e.g. you can't get 10 amp fuses for a spur that needed one).
Anyway, we had previously agreed for an accessible joint where the break into the existing ring would be, covered by a blank plate. I asked whether he would earth the back box and he said that it would affect the reading when he tested the extended ring, so he didn't. I would have thought he might have done it after the testing but as you can see from the picture below, the earth terminal in the box isn't being used. I would have though that a bit of sleeved 2.5mm copper from the box to one of the earth block connectors would be good practice.
Do you agree? I also had a MK Grid switch setup also wired up and this back box also isn't earthed. Wouldn't be a big job for me to correct this but just checking it is the right things to do.
Any thoughts much appreciated.
Many thanks,
Damian
Many thanks,
Damian
