- Joined
- 28 Jul 2011
- Messages
- 6
- Reaction score
- 0
- Country
Got a quick (i hope) few questions...
I am intending on replacing my current plastic bath with a steel enamel coated one. And I have some questions on earthing requirements.
My mains water, gas, hot, flow and return are all copper throughout and are bonded together. The gas is connected to an earth block near the meter which is in turn connected to the earth from the ground. All via earth cables... done when house was re-wired (by a qualified sparky).
I understand my bath needs earth connection, as I assume that all my pipes are already at earth which are in turn connected to the bath is not sufficient?
Can I simply connect the bath with the earth cable to the pipes (using the clips) or do I have to have go back to earth block? If I have to go back to the earth block, can some please explain why?
Is this work notifiable to my BC? I understand that I can legally do this myself?
I am also considering installing a bathroom radiator, does this need to be earthed even though the pipes to it are already 'at earth'?
