- Joined
- 24 May 2016
- Messages
- 3,880
- Reaction score
- 758
- Country
Easy to buy straight connectors however not all plastics are the same hence there are different solvent weld cements out there.Ok, big assumption but If the external diameter of the existing pipe is 40mm, then you can get 1.5" (38mm) solvent weld couplers from here
Right I'll shut up now other suggestions are probably better.
