If it is the large doughnut washer, then again it means the cistern needs to come of the wall right?
Will have to check.
Is there a t particular reason why they don't make the diaphram more solid or tougher? I'm trying not to be cynical and think its because they want you to replace the part. But I can't find a logical reason why this part cannot be made to last forever since all its doing is holding water. If as someone above pointed out, it is made of cut out plastic milk bottles, how is that likely to fail unlike a think plastic bag membrane type?
Does the siphonage concept also work for the flapper type system - if not how does that work and is that also prone to failure like this one after a few years?
Thanks everyone for their comments. I learnt something from this. One last question: what would a reasonable plumber have charged either to replace the diaphram or to replace they whole syphon if the diaphram alone couldn't be replaced. Say London rates.
Cheers again.
Cheers again.
