I moved into a property with Economy 7 and have a few issues. I have only ever had Gas central heating before and am a bit lost.
Firstly does E7 have a thermostat like you would find in a gas heated place ?
My Emergen heater works fine, however whenever I try to set the timer the clock does not rotate allowing this to work and switch over. When rotating the dial switch around the on/off for the timer switches but the clock doesn't actually rotate.
The timer is a TS900B identical to this one:
http://www.amazon.co.uk/Timeguard-TS900B-Immersion-Heater-Controller/dp/B00BONIKDQ
Also I cannot for the life of me get my radiators to work.
There is one power switch for the radiators, that I have turned on and left like this for 48 hours yet still no heat comes form it.
I have checked my fuse box and everything is fine there.
Any ideas of what I should do, as I think its a fairly straight forward thing but for the life of me cannot figure it.
Any help would be greatly appreciated.
